re: The Bent Zombie Tribrid Tadpole Trike (build phase)
Yeppers, defo need the lights n'stuff given how short the build is & the nighttime wanderins ... tho I s'pose strobes might be a bit much![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thing is, in this as well I seem to have almost too many choices - I've a complete harness from the donor four-wheeler (keyed ign., tail/brake & headlight, ripcord & thumb kill switches) and interestingly, my electric hub motor's switches & controls are wired for: horn, tail/brake & headlight, blinkers & cruise control - it came with both thumb throttle & twist throttle controls, switched brake levers & all the assorted doodads, then add in this lil box for;
Programmable Cruise Controller v2.0, GMCanada
Cruise Speed Control
Programmable via PC to setup motor control parameters
Motor hall sensor failure redundancy (Automatically switch to sensorless control)
Anti-theft alarm and wheel-locking by detection of vibration
True regenerative braking (only effective when you squeeze the hand brake)
Other failures redundancy (Work with failed throttle and power breaker)
Forced function with lower voltages (e.g 48V to 36V, 36V to 24V)
Report failure components by beeps
Motor phase self detection and calibration
Support Forward and Reverse Control
Excessive Current Protection
Low Voltage Protection
So... I've not quite figured what I'm gonna do with alla that lol @.@... prolly gonna run with the four-wheeler harness for ICE ignition, key switch & it's charging sys and the hub controller for the rest.
The ICE doesn't actually have an integrated fan, despite that I don't think I should have any cooling problems, the motor is actually slightly less obscured than it is on a four-wheeler with it's plastic cowling, even on the wee 49cc like mine. It's a concern though & I'll likely get a small CHT/EGT combo gauge jus' for the lols if nothing else: FALCON GAUGE 2 INCH ROUND CHT/EGT GAUGE 100-700°F / 700-1700°F from Aircraft Spruce
If cooling is an issue, it shouldn't be much of a challenge to add an induction scoop or two![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
