frozenveinz
Only place I can think of is Duane..
Sorry it took so long to arrive as some guys contacted me and bought all my RT carbs and I had to wait till my new shipment arrived any day before I could ship yours to you. We now have them back in stock and shipping. They are popular carbs and almost all buyers report 2-4mph gain, all report better throttle response and superior idle along with bigger torque in the mid range. Enjoy the ride..
An air leak can easily = a fast, uncontrollable idle.
I removed it, cleaned the sleeve and sanded the chrome intake a little and sealed the carb to the manifold with SealAll, gasoline resistant sealer/adhesive and waited until today to test. It runs great, maybe a little better than it has for a couple of weeks.
The plastic sleeve that's in the carb throat is intact, no apparent place where it could allow air through but after it was sealed my idle went back to normal and the surging went away. I did not disturb the intake flange gasket but checked the tightness of the fasteners. The leak was in the plastic sleeve, I'm certain.
Just thought I'd pass that along to you other RT owners.
Correct. The air leak obviously was between the plastic and the metal parts. I applied Seal All to both the inside and outside of the plastic sleeve.So your leak was between the plastic and the intake. not the plastic and the carb? and you said you used some glue so is the plastic part attached permanently to your manifold now? also, i have an o-ring from sbp in between the manifold and the back of the plastic part. seems to still be leaking somewhere.
SealAll is a very good product, as GearNut said. Much better than most silicone based sealers. If you check the label of most silicones you'll see they are not meant to be used in direct contact with gasoline. They'll work as a sealer on the carburetor temporarily but will be softened and become gooey after some time and allow air to pass.
SealAll is formulated for repairs to gas tanks, fuel line connections etc. and is completely uneffected by gasoline, even it it contains ethanol.
The parts can be disassembled when needed.
