Motorized Bicycle Take a Tip...Leave a Tip
[QUOTEATTACH]61132[/ATTACH]
View attachment 61131[/QUOTE]
i HAD THE SAME EXACT cRANEBROOK HUFFY MAY i ASK WHY THE MOTOR IS SO HIGH UP ? i COULD UNDERSTAND IF YOU HAD THE PULL STARTED AS i DID BUT i GIT RID OF MINE DROPPED MOTOR DOWN WHERE IT WAS ALMOST LEVEL AND IT RAN SOOO MUCH BETTER
p.s. i CANT BELIEVE I just typed all this in caps
Here is a little tip that has been useful for me at times.
After measuring my front wheel I always write down the code on my speedo just in case it resets when I am out on the road and cannot remember what it was.
Thank you everyone, great tips!
My Tip: Make sure you grease up your chain regularly as it will dry out and might crack and it will just not run as well overall. When you do grease it use Liquid Wrench! Best stuff i guarantee , and don't just spray it all over the chain everywhere and get it all over the place, Put the straw on it and spray it right into the feeders for the chain and you wont have to do it as often and it will auto lube it as you ride.
Liquid wrench wets the chain but does not last like proper chain lube.
It is thin and made to penetrate rusty bolts, not chain rollers.
It gets in good, but does not last.
That's specifically what liquid wrench is made for, and whatever your preference may be of lubing, Just spray it right into the feeders.
Be sure to upgrade both the pedal and engine chains at the same time. I suggest using bmx chain for the pedal side, and reinforced 410-415 depending on your kit. Both chains can break
Liquid wrench and W-D 40 type products are not meant for lubricating anything really, you'd be better off applying some 3 in 1 oil than liquid wrench, that stuff wont last around the block for a chain lube, it does have it's uses but not as a chain lube on a motorized bike, I ride in very dusty conditions and I do not oil my chains period..... I do coat them with a dry chain lube that sprays on as a liquid, penetrates all the moving parts of the chain and then dries leaving a slick Teflon coating on all the parts I then apply some Maxima Chain Wax, my chains hold up well even though they are covered with dust always, oil attracts every kind of dust and dirt around and will cause the chain to be all caked up and nasty.
pics show what I use and I have yet to wear out a chain or have one break on me on three bikes and the oldest was built in 2009 and has 2000+ miles on it now.
A high-performance, O-ring safe chain lubricant, DuPont™ Teflon® Chain-Saver Lubricant utilizes a patented formulation, so it resists dirt or will not fling off the chain. It can help chains and sprockets last up to five times longer.
Peace, Map
Dunno if this has been done before but as I learned today: When you take hardware out, CLEAN IT UP. AND RE-LOCTITE IT.
Just do it, save yourself the trouble on the side of the road when something falls off or you lose your clutch. :)
I lube my chains on the beast when they start getting a little noisy. Often what I do is roll up a piece of paper towel, fold it over and use the 'open' ends a bit like a mop-brush. Dip in a bit of oil, and then swab the chain. I turn the wheel to move the chain until I can get it all wet, then rotate a few more times to work the oil in.
On my cruiser I haven't had to lube the chain yet, but it soaked for a while (okay, 3 weeks I think) in a mix of "Phil's Tenacious Oil" and some stuff a neighbour gave me that (he said) they used to add to old differentials to keep them moving smoothly called "Microlon Compound 90" before I installed it. Around 2 oz. of each (half bottle of each). I just rolled the chain into a spiral to fit the bottom of an old plastic food keeper tub, poured them in on top and left it (with the lid on) where the sun would hit it in the afternoons. Also, I hung it from a hook for a day or two to let as much of the surplus drip off and back into the tub before putting it on the bike.
The other day I was heading home from work so I pedaled down the hillo let the clutch and bang the next thing I see is my idle bushing passing me doing about 20 mph , I guess the bearing seized up because the race was left on the clamp and bears were stern about the road so after pondering on what to do and almost accepting defeat I was about to field cut my chain to limp her home when all of a sudden in my bag of possibles I see a socket and that shiny chunk of metal was like an island in the middle of an ocean The god like "AHHHHH" sound went off in my head and I used that 3/8" drive 3/4" socket to limp me home the chain slid nicely over the socket I had a couple over i sided washers I put on either side and used a bolt it didn't spin but at that point I didn't care Work enough to get me home
Simple tip that will save you a lot of hassle. The clutch cable spring (the smaller one, not the heat shield), just toss it and install without the cable. Will save you plenty of hassle. Also, use some WD40 on the cable innards.
Another tip, get a double brake lever and connect both front and back brakes to it. That way you engage both brakes with the same lever, leaving more real estate on the other end of the handlebar.
Cheers....
