Re: The Bent Zombie Tribrid Tadpole Trike (build phase)
A bit less exciting perhaps but still defo needful is I also got my new front derailleur and teflon chain return tube as well - the chain tube was the
perfect length and was no more bother to install than a coupla zip ties & finally having the proper front derailleur means I can finally trim down the excessive stub of what used ta be a seat post when I get a mo.
Make no mistake however - these pics are
very deceptive, there's still a LOT to be done with much of what's in the pics only rigged up to see if it works... to give you an idea, here's a
partial "to do" list, stuff I actually know I still need to do lol;
Weld cable stop front derailleur
Cut down front derailleur mount
Pedal boom adjustment lock
Brake noodles, front brake calipers
Shock mount nylon shims
Lathe new brass A arm bushings
Drill steering plate pivot for castellated nut
Recenter lower seat mount
Battery tray mounts
Return spring ethrottle
Weld handlebars
Trim linkages/final alignment
Trim handlebar cross bolt & nyloc
Final weld upper rear shock mount
Gusset rear stay pivot
Fabricate rear rotor spacer plate
Fabricate rear caliper mount
Fabricate torque arms for hub motor
Trim jackshaft, cut keys & spacers
Rear derailleur mounting
Relocate foremost power idler
Fabricate rearmost power idler
Weld idler mounts
Replace fuel tank mount bushings
Routing electrical harnesses w/looms
ICE fuel system & remote choke control
...aaaand, not only does that list neglect the things I've no doubt forgotten, naturally even after all that's done - I get to rip it
all back down to bare chassis, sandblast, prime & paint whoohoo!!1!
I
love this hobby lol
![](/proxy.php?image=http%3A%2F%2Fi305.photobucket.com%2Falbums%2Fnn210%2FSerenity151%2Ftad%2Fth_847ce22c.jpg&hash=e367d83a2702b839639e9ecd539ee4ad)
