hombremosqa
norman, i rebuilt my carb a few days ago, and moved the E-clip on the 3rd notch from the top. it runs smoother, but im still flooding the cylinder with gas. i did adjust the float, but i need a measurement. any ideas?
Thank you Very much norman, I could not figure out what was wrong with my bike, i have now realized the needle spring is not at that second placement, but most likly at the bottom, running very rich.
this was causing my bike to have a top speed of 30kmh. and horrible gas mileage.
Ya know I've never owned anything that had a carb with a "tickler". So, is it just a way to prime the engine by depressing the float to allow more gasoline into the carb ? It seems like it would create a condition like slightly flooding the engine a bit so you have a rich start condition.
When I was a kid there were some older guys with Cushmans and "Mustangs"
that I would see reach down and hit a "prime" two or three times before kicking
the starter. I once watched this guy who had recently purchased one of these old bikes and was kicking himself numb. I'm with my mom and at like five years of age point out to that part of the carb (as I'd seen these other guys press on it a few times) and the guy looks at me dumbfounded. So he does it and kicks the starter and it starts. He pulled out looking at me in shock.
So.....is this tickler a primer or what ?
push it together. you can do this on the bike if you got the room sometime you will have to remove the aircleaner to mount the carb on a tight fitting frame. after pushing it together just a little twisting to help spread the silicone and aline up the casting seams on the carb and the manifold tighten the bolt and TADA.( I polished off the seam fooling around with the polishing wheel and never mind the weird fitting its for a boost bottle and I wanted to try one so I made one. I would recommend a tuned pipe money better spent and thats my 2-cents but they don't hurt anything and if you want it to look cool sticker and all go for it. I did find the engine will idle at a much lower setting on the idle screw and the thing seems to run smoother but top end nada.
I realy don't think it's worth the money for a boost bottle and besides you end up with a holed manifold so now I will need to make a steel one someday. I make offset intake manifolds on special order for $30.00 shipping is $5.00 if you want to make your own I can sell you the machined part that goes into the carb its a little short stub of machined steel for $10.00 if you can't find one or don't have the tools to make one. PM me and I can knock you out one even an off set one
