Bikeguy Joe
Excellent tip.
A lot of weedeaters and chainsaws have ticklers on themll
What is that screw next to the Tickle button? and What happens when you adjust it?
I think its the idle screw, but since I'm a noob, i might be wrong, I'm just trying to make sure.
very helpful, and, though I was able, thru a tear-apart, to figure out most of your' info for myself, I'm haveing another problem with it that I hope you can help with....I've installed a new carb and cable, and adjusted out both ends to the max, hoping to take up slack, but I'm getting no response at the throttle, there's no return action. I've looked thu the air intake and can see the needle in in the hole, but the twist grip dosn't spring back, and I can't see if the needle is moving...any suggestions?...don't really wanna take off the bottom of the carb to see if needle is playing..(gasket is such a pain!)..but the return spring dosn't seem to be returning the throttle!Hi guys!
This carb. is being throwing the gas by the floats chamber vent hole. I set the needle in the first notch from the top and remove the air filter getting better results but still leaking the gas. This engine is new, run his first gas tank already, but with very bad MPGs.
Do you guys knows what's going on here?
YouTube - Motorized bike 66cc carburator floading.
At the end is noticiable the oil in the floor, comes out of the exhaust.
float how it looks when its upside down I'm sure there's a measurement in china but I don't know what it is I should have measured it in the pic. this photo the float isn't setting level but it should be my mistake when I took the photo. With the float setting level it should get you in the ball park.
adjusting the float for the fuel level this is something to do only if you can't get it to stop flooding or over filling the bowl with fuel. If you ruin it you most likely will have to get a new carb. I haven't checked on parts at the cycle shops. I'm showing where to bend it I don't recommend bending the tangs as it would be hard to get them the same and they probably are not the same anyway but if you can try to get the tangs close to being the same then bend where I'm showing in the photo try to get the float level with the carb upside down. messing with fuel level in the float bowl will affect rich to lean to a degree how much on this thing I don't know. lower fuel level equals learner mixture and can starve engine and you might burn a hole through the piston. something to think about. Do a plug check when messing with the carb.
A quick and easy cave man check to see if the needle and seat are working. attach a short piece of fuel line to the carbs inlet fuel nipple hold the carb right side up using your lungs blow into the fuel line as your blowing into the fuel line turn the carb up side down you shouldn't be able to blow through it then. Hey don't do this with fuel in the carb fuel is not good for you and don't suck on it for cryin out loud!
is running awsome.
i live about 5000 feet up in the mountians of mexico and was wondering if i should re-jet my stock china girl. it runs alright and i am going to fidle with it tommorow. Also, i would imagine i need a little more air to get into the carb, is there any diy things i can do for this as it is very hard to get parts here
