You have a massive air leak probably where your carb goescan you tell me how to adjust the carb? my motor is running wide open and i have no throttle response. how do i fix this? i want to ride, not spend the two weeks that have passed trying to get it to work right. please help.
Can you explain it a little better do you have no throttle response? Will it idle and not rev up?
Or once you start it it goes wide open and won't slow down?
Norman
Thank you taking time to help us. My problem still persists, fouled spark plug, gas on the piston, have to remove spark plug and clean & remove head and clean gas off after every ride. followed your example's, seem's to ride allright, higher speeds sounds like it works to hard, watched Youtube videos and my ride is not as smooth, don't know as much as I'd like to properly explain, if you have paypal wouldn't mine a donation. Thanks
