MEASURE TWICE
Yea it is coming together real good!
Just your gas cap a temporary, it does not look like a vented one?
MT
MT
MT
I see a pulley on the engine now, are you going to have a belt(s), jackshaft, and for a rear wheel drive a whizzer or washing machine pulley on the rim or spokes?
I used a type of belt that has links to add and remove to change length. Recently I felt that it slipped badly and links came apart when tightened a lot.
Now I am going to try either a regular vee-belt or another link type belt I just got, it is the Power Twist Plus instead of Accu-Link. Power Twist Plus seems way more rigid and should not stretch nearly as much and hold up I hope. Power Twist Plus notes that pulleys smaller than 3 inch diameter should not be used, which is why I’ll probably use at least one regular belt for a 2 inch pulley I am using.
Great seeing the progress you have made and as SB says the interest is definitely for a major part the non-kit aspect.
MT
http://motorbicycling.com/showthread.php?t=29678&page=7
Just spent a few minutes staring at your bike and thinking about things I like about it. One is that it was your Dad's bike. That's pretty special to begin with. Every time you ride it in a sense he'll be riding it with you. If he was like most boys I imagine that he put playing cards on the spokes or at least imagined it having a motor. Now it has one. How cool is that?
I like that the motor is different and that this is not a kit build or everything off the shelf. Nothing wrong with that, mind you, I just like seeing things that are different at the core and not just on the surface. I like the way your air cleaner helps to fill out the engine space which makes it look more like it was made that way back when.
Get used to the idea that old guys are going to come out of the wood work and ask, "Is that a Whizzer? I always wanted one of those. My uncle had one just like that!" And whatever is said, it is with smiles when the boy inside speaks up wistfully once more. Any of us back then who had real blood in our veins became lustful to have one when we'd see an ad for a Whizzer in a sports magazine or Popular Mechanics. .. oh man! So be kind to the old guys and let them be wide eyed boys again while they stare and babble. That's one of the highs of this hobby, being able to share the joy of a hand made time machine bridging then and now from little boys to big boys to old boys... it all kind of melts together in the mechanical moment. Cool stuff. Cool bike. Wait til you take it for the first motored ride. Do have someone taking pictures!
SB
If you choose to remove the whole section of fender you will get dirt and grime slung forward of the tire and all over the backside of the engine. You could still offer protection by using a rubber "skirt" between the fender stays.
Or just notch the fender.
If that is the original fender I would find a doner fender to cut up. Don't cut up your dad's original fender.
I really like the battery box idea. That would look really cool and double as the road grime shield,
I wouldn't want to chop up a 1958 fender either. I think I would just find any old fender that fits (or you can make fit and looks good on it,) and chop it up instead. Put the original in storage. That way you have your fender and your battery box.
fatdaddy.
