Southgate Jonny
My relatively high-compression engine runs noticeably cooler since switching to Opti2 @ 100:1...
I must be doin it rong, LOL!
Thanks for the enlightenment. That is indeed a unique design.
Mounting position wouldn't be an issue if I understand the concept. No sump, no worrys about keeping oil in. That would give you the option of slanting the cylinder toward the front instead of backwards like some of the 4 strokes currently popular. Would certainly improve the aesthetics.2 cycle oil Tom, amsoil sabre 100;1 I want to get a br600 still motor it's 4.5hp probably get it on a bike easy ..
Installed a Dax balanced lower / 69cc top end / slant head today. Running Opti 2 @ 80-1 for the 1st 1/2 gallon because I'm not macho enough to go w/ 100-1 from the get-go. Anyway, this thing is smooth and crazy-fast!
I just ordered a Dax Type D F-80 balanced low end
this past Friday Dec. 26th W/$ I got from Christmas lottery tickets!!! Cha ching & I cant wait for it to get here!![]()
Do you have a NT carb? After running Opti at 100:1 mine was 4 stroking a lot with the stock jet, I installed a 68 and it improved it the issue slightly, then I switched to a 66 and it runs way better with just a bit of 4 stroking at about 1/3 throttle and again at about 2/3. I may order an even smaller jet to see if that will eliminate the issue altogether.
Yes i have a stock NT on mine. I have the same 4 stroking problem but eventually i will go to a reed valve and a different carb I have been ordering my parts piece by piece
