Hey Whozawhat, I really love the bike you built.  It has got to be one of the top ten home built vintage bikes I have ever seen.
Thanks
I have a few of questions:
What is the top speed so far?  I realize its meant for slow cruising, I was just wondering what it could get up to with that engine.
In numbers I don't know, but you would have to run your ass off to keep up with it at WOT
Your belt installs into the bike frame through a "gate" in the frame, right?
right
Has that joint proven to be a strong enough frame member, given it is joined not through welding, but bolts?
so far so good, and I could stand to loose a pound or two
Finally, on your front end suspension, how much travel does it have?
at the axle about 3 inches, however because of geometry and levers the tire to fender only moves about 1.5 inches
The front fender looks so close to the tire at rest, does the tire ever rub the fender when encountering a bump in the road?
yes at first until adjustments to the fender stays were made, now it is fine
Sorry for so many questions.  Like everyone says, you should be very proud of your motorbike.
Gilbert
