Davezilla
Got a chance to do a test run with the 40 tooth rear sprocket installed and top speed felt faster but once I got to the resturaunt I noticed my gps was turned off on my phone, then on the run back the engine cooled down too much and I really didn't have enough time to let it properly warm up but was still able to record a 40mph top speed reached 4 stroking all the way...
Also my 21mm carb finally got here and it's a perfect fit to the intakes MZMiami sells on ebay except it needs a small section of hose to couple the 2 together since the Dellorto clone is a spigot mount type. It'll probably be next weekend before I'll have the time to install and tune it since I set up a job this sunday to change out a rear main seal on a customer's car and won't have the time to mess with the bike this weekend.
just a suggestion. when you put the head back on get 4 nuts that fit the cylinder bolts and tighten them down first then put the acorn nuts on. I have found that sometimes the nuts bottom out and you think that the head is torqued down to 12 foot pounds when really there not. I used allthread connectors as my bolts they work great and I put a small stud in and tighten the acorns to them they look like a taller acorn nut and your sure to get the right torque.
