Yes that is what i area i was talking about its the area where the gasket meets the front mount it is protruding about a centimeter out and into the mount, do you think that it would possibly leak enough to stop the engine from starting altogether? or maybe a leak in another area *considering its so poorly done that the gasket is in the mounting area*, most of these leaks cause lack of performance (as far as i know) i've never heard of a compression leak in any of these forums that would cause it to not start other than people blowing there head gaskets, but thats not exactly a leak either.I think you are talking about the case gasket....the gasket between the two halves. Is the gasket protruding at the front or rear mount.
This picture was for another member. The only leak in the gasket that will effect the engine is the part that surrounds the crank shaft area (where the bearing is).
![:-|| :-|| :-||](https://motorbicycling.com/images/smilies/Waa.gif)
