Very cool Ilikea (and thanks!)
Am on my way to buy a battery for it. Thinking as big as I can get, deep cycle? What do you think? Gotta buy one for the dang mower too. It took 3 junk mowers to build this one and it looks like it, lol. Putting a hood ornament and umbrella on it, hopefully today. Yep, said that last yr. Live in a very,,, lets say reserved area. When I work on the yard, people ask me how much I charge. So gonna ride my junky lookin' rider mower with a Mercedes-Benz hood ornament, Hunter S. Thompson sunglasses, beach umbrella/shade devise while sipping some exotic looking drink with it's own lil umbrella with, what ever I am, pride. snork
What were we talking about? LOL
Dan "never on topic" Keav
Framing the walls today. All crown out(.?) Kinda exciting. Really starting to look like some thing. Must sound kinda silly to the pros and well practiced but is the biggest and most complicated thing I have built.
Question, the studs fall in between the floor joists according to the plans. Is that right? I was under the impression that each wall stud rested directly on top of a floor joist.
I quit using nails for framing. I started using drywall screws. It's a little slower than nailing (especially if your using a nail gun). But if you make a mistake it's a lot easier to take out a screw than to pull a nail. In fact some of those coated nails you can't pull without tearing something up....
yep,crown up,studs line up wherever.i prefer nails and screws,depending if i ever need to take something apart.when you put the sheeting on the walls,don't forget to drop it 1/2-3/4".it helps keep the rain out.on the topside,whatever you drop the sheeting will be covered,as the soffit hides the top few inches.there's plenty to nail to if you used studs,they are shorter than 8 feets due to the bottom plate and double top plate which amounts to just around 4-3/4 inches.
hpoefully you have the foam gasket that goes between floor and wall.
Dan if you are going to add drywall or maybe osb board on the inside you need to use corner posts on one end of each wall. cut three blocks of 2x4 about a foot long then sandwich the blocks between two studs one on each end the other in the middle.When you slide the next wall up to the corner you have a stud to nail drywall to. To see what I am talking about stand three studs on edge then lay one flat to the outside edge the resulting ninty degree would be the inside corner if that makes sence.
the sill gasket is exactly what i was talkin about.3.5 or 5.5 inches depending on wall thickness.
i tried a search on california corner framing,it uses less lumber and is more energy efficient,but my dern interweb is not cooperating tonite.
gives room to stuff insulation in the corner.
my brother in law insulated his garage he framed in a 45 degree angle where ceiling meets wall,so he could run a full bat continously from wall to ceiling.
aparrently it makes for lots of energy savings.
DAN
Nice thread and building with new material is "more gooder"! Remembering straightening used nails and used lumber as a youth. "The Good Ole Days!! lol
Waffel Hammer!!! Hit my thumb with one yrs ago, thumb looked like a waffel!! Owie!
Set the walls and roof on House Boat with my "Tonka" truck. Most of my tree trucks were painted yellow.
Last week, bought an 8000 btu ac for my "$500." 12 ft x 20 ft insulated, wired, sheet rocked textured and carpeted shop. "Previously Owned" lol.
Hauled it 30 miles on the Interstate Hy with 30 ft boat trailer. Would still be in jail if DOT got me.
Been dragging stuff out there and started stripping the 140cc clone for the stretch cruiser.
Maybe should fix mower first, can`t hardley find the outhouse ect.
Ron ......---...
PS; At the lumber yards here, the straight 2 x 4`s are free, but you have to buy the crooked ones!!
