A lot of people are running opti-2 at 100 to1, I have only run it at 71 to 1 or 1.8 oz to a gallon . two different motors and both have run good.
Check the date of the original post in this thread. 2009.So, is the consensus that Opti-2 is recommended for our 2-stroke motors? I just ran across this thread, and I was surprised to see that it's such a small amount of oil for a gallon of gas.
Because it isn't how much oil you use, it's about the lubricating ability of the oil.My question is WHY, do you want to run less lubrication? I once was
a Amzoil dealer.I also raced Karts.Amzoil came out with there 100 to 1
oil.
In racing kart engines they run 20 to 1 & if you try to go much above that
watch out (ask me why).Well I was scared to run 100 to 1 so I mixed it
50to 1.Guess what, the engine stuck after lap two.
Now ask your self why you want less lube in your engine?Is it cause you
want a cleaner burn?Well todays Synthetic oils are very clean at 32 to 1.
It is you call & engine.
Fly
Couldn't have said it better myself...This is a crazy thread that refuses to die. As if all oils are the same. Obviously they aren't. Read the label from the manufacturer. If it says 50 to 1, then do that. If it says 100 to 1 then do that. How long do you imagine a company would stay in business if engines were blowing up? I've been using this forever it seems. I especially appreciate it in my chainsaws where I am right there by the exhaust. Burns clean. Enough said.
SB
I agree 100%Because it isn't how much oil you use, it's about the lubricating ability of the oil.
Like has been posted in this thread many times; if you don't want to use it, don't. But I would think it would be difficult to argue with the success rate of those who do.
A 5 year old engine with 55 hrs. on it doesn't really prove much. Put 550 hrs on an engine at that ratio and I'll be impressed.
I hear what yer saying ck70 and the fact that I don't even run china girls makes my point useless anyhow. The only 2-strokes I run as of late are CY 46cc chinese Zenoah clones.Scotto
Defiantly not all, but a lot of the engines being discussed here are 66cc china girls. I am not really sure if anyone has ever determined how many miles one should expect from one of these $100 engines? 100 hours or so may be the very best one should expect from a china girl...heck I don't know.
I am not familiar with the CY46's, but I have sure owned a bunch of Zenoahs. I fly giant scale RC airplanes and always liked running Lawn Boy Ashless oil in those at 32:1. The Lawn Boy ashless oil always seemed to burn fairly clean and not smoke out the guys in the pits while the plane is on the starter bench. I have also ran synthetic at 100:1 in a G23 as well without issue, but for example I am only spinning an 18X8 prop on a Zenoah G38 at around 8500 rpm and no where close to what you are spinning those CY46's up to on that bike. So I am not real certain how the Lawn Boy oil would hold up to those RPM's or even the synthetic as far as that goes. 22,000 rpm is really cranking and I doubt there are many in these forums cranking up those kind of rpm's. So what might perform great in an engine at lower rpm's may not perform at all in the same type engine spinning up to ballistic type rpm's.The only 2-strokes I run as of late are CY 46cc chinese Zenoah clones.
( for the record my CY46's turn 18,000-22,000rpm maxed......seriously)
The most expensive sound in powersports - Silence.Guy,s I could give a sh!t what you run or what you do.I just told you
about sticking a pistion on a racing kart engine, in just a few laps using
Amsoil 100-1 & even mixing it at 50-1.
I also ask what you thought you gained running less lubrication.No one
said anything about what you should or should not do.This form is to
share info & let the people reading it make up there on mind.
Like I said before it's your engine not mine.
Fly
