Silver bear I have 3 of those aluminum holders mounted on rear racks two are 36v 16 amp he & one is 48v 16 amp he all are from china and all have lasted 3 years and a lot of recharges the 48v is about to be opened up as it's not wanting to charge up. I'm thinking these all have Chinese cells, but we will see. I'm hoping and think the cells are fine but suspect the BMS is bad and won't reset properly. None of these packs were expensive and like you said the aluminum case adds $30 or so. The slide on, locking mount/on-off switch works well. I mount mine on a rear rack, but down tube or seat tube is great, if there's room.
I'm hoping you will be pleased with the packs performance. I pedal continually and use a twist throttle (no pedal or cadence sensor) and get really good mileage as a result plus exercise. My Mountain bike gets serious miles on a charge but that's pedaling with a 8 speed Shimano derailleur, never tried to test with motor power only though. I tested 3 of my 36 v packs this week they were fully charged. One was 41 volts, one 37.7v & the other 39 a. Thirty six 10s packs do vary a bit and of course age and number of recharges plus add ambient temp matters as well. I have one pack 36v that never charges past 35v I'd think this pack is only at 80 percent of it's capacity when new and it performs great just won't charge up to spec.
In studying up on lithium pack repair I see a lot of BMS problems and the stated reason is using very poor quality think cheap, BMS even with packs having quality brand name cells. Cutting corners? Good BMS replacements of 30amp are quite inexpensive, but tech time is expensive. The hub motor kits use, typically, throw away controllers of 20 or 30 amps (48v kit) I'm in the process of upgrading controllers as they fail, using 30 amp for 36v battery and 40 amp for 48v motor sets.
By going up 10 amp on 36v motor, 20 amps to 30 amps, 360 watts are gained making the 750 watt into an 1,100 watt. Speed is the same, but torque is increased. 48v motor with 10amp controller increase gives3/4 hp gain. Either one is a huge gain in hill climbing and acceleration.
When you buy a hub motor kit grom a specific supplier,chances are the selection of 500w, 1,000 watt and 1,500 watt motors are the exact same motor but supplied with 3 different amperage controllers. Some will have a 750 watt offered as well.
Of course increased amps will, if used recklessly will really drain a battery. On road trips I use enough throttle to keep the bikes pace and enough gear and pedal pace to steady my speed. I typically coast descents or just pedal a little to keep my speed constant.
On short rides under say 15 miles I still pedal but some don't want to and usually they make it home under motor power, if not they pedal and or walk it home. I say told you so....
Anyway glad you guys are finally getting into this as well as gas bikes. Our hobby doesn't have to be either or both are fun and fine!
Rick C
