Let's see some pictures , of this bike , you've been working on , spending all the cash on...
Same here, sorry.mapbike, utube says "this video is private" and I am locked out.
So far I haven't found any mechanical speedometers that will last on my bikes, I've destroyed several and some were vintage and really nice speedometers and that just made me sick to know I ruind them....Ordered a new Mechanical Speedometer the last China made junk I bought lasted 14 miles before crapping out.
Im hoping the crank is still ok, but the case is probably junk, im thinking that one of the bearings probably spun in the case and ate it up allowing the crank to have the end play it has, when I get the engine off and tore down Ill know for sure.'http://file2hd.com/' brought the vid down OK - yes, that looks like a failure in the mains
The crank should still be ok, I've had the same type of issue on my previous engine, that one was working just fine and I took it apart just to do a quick post break in inspection when I found out it had about 1/8" of side to side play. When I took it all the way apart, all the individual parts looked good, including the bearings, but it had that play so since I had the crank out I put it on the lathe and corrected the runout, then I put in the good bearings, the original bearings were good, but I wanted to put the good stuff in while it was apart.Im hoping the crank is still ok, but the case is probably junk, im thinking that one of the bearings probably spun in the case and ate it up allowing the crank to have the end play it has, when I get the engine off and tore down Ill know for sure.
Map
Will do, im hoping that I'll have time to take that engine down Wednesday or Thursday.I had pretty much the saem issue with my old engine too because I really don't remember it having any side play when I had it apart before running it, but it did turn over nice and free when I checked it before putting it together for the first time, then after about 10 hours of run time on the engine I took the jug off to inspect it and that's when I noticed the play. Mine had about 1/8" play in it but I didn't see any other issues that could have caused it. I could only imagine what 3/16 to 1/4" of play could do to the case covers and cases tho... Hopefully the cases are ok and you can shim the crank with spacers.
Anyway, let me know what you find out when you get a chance to take it apart
Im jealous. .. I had to sleep most of the day since I have to work all night, would much rather be riding a bike.Did a 32 mi cruise. awesome I love my bike!
