I'm 6-2, 225. Not a lightweight.
I got the 1 inch roller, thought that best. I have another Staton with the 35 cc Robin Subaru and that is a sweet bike. That I got the 1.125 roller on. Works good.
The Tanaka has a little less torque, so I went a little lower, should be about the same. Gonna scrap those cheesy tires I put on there so the Solex roller would fit and go with a couple of old fav's the Serfas Drifters.
Hehe, the Solex wouldn't run good w/o 55 psi in the tires.
It's really tearing me up. I loved that old putt-putt. That motor has enormous low end torque and will run fine walk slow. I used to just comp release and let it roll down the driveway hill and let go and off it would putt. When it don't putt it's **** to deal with.
I'm too old for this crap anymore. When I want to ride, I want to ride, not play the drizzle gas, check the tiny pipes, drain the tank, remove the pump and all the plumbing routine. Then screw it all back on and find that it still don't work.
I'm going to see if I can do a spring loaded thing on this one so I won't even have to worry about setting the struts and the skewer thing.
