Put on this fatty pipe yesterday, lost a little bottom end off my home made pipe but the mid and high is buck wild, she wants to really rev out but it seems like the cdi has a rev limiter or something
actually vik, i found out this morning that i will not be homeless after all...things have worked out, for a while at least, and i will still have a place to warm me bones...got a flying horse on its way and am going to be stuck using the same old solid mountain bike i used on the last build, but its comfortable for me...im 5'11" and the 26 wheels are great...need to acquire a springed seat, and maybe find someone junking an old mb with spring or shocked front end...the rigid kills me...pics to come of the new old build...
Did ya open up the intake before ya put the carb on. Even the gasket they give ya is too small. The flange thats welded to the intake tube can be filed out and opened up A LOT, and the gasket to match. And as long as you have the intake off, check the intake port. A lot of times it's not really as smooth as it could be, The casting is always jagged. better air/fuel flow may just solve the top rev problem.
fatdaddy.
And OH YEAH, No rev limiter on the CDI. When was the last time ya changed yer spark plug?
Looks sweet
I'll take the old pipe off your hands if you're not going to use it haha
I need to get my hands on a decent welder first![]()
Forced air intake?
Think MUFFLER SHOP! They weld a little cheaper than the machine shops. I did that for a couple years before I got mine. But ya gotta catch them on a slow day, Otherwise they will charge you up the wazoo.
fatdaddy.
Not really, not like a turbo or anything. It's just a stationary "fan" with an ace bandage and hose clamp over that rubber boot. (see album). The air going over the bike goes straight into that boot though. The idea is to force the air to spin in one direction to prevent pulsing, and pack more air into the carb.
Google intake tornado for cars, it does the same thing.
If you want to see how it works, cut the bottom off a 2 Liter bottle. Cap and fill the bottle. Let it drain (glug glub glub). Do the same thing with the little fan laying in the bottom. (Shoooooooop -empty)
You can get the fan blade off with a big flat blade screwdriver by gently prying and turning from under the center part, and prying the magnet out. They are free in the trash at computer stores.
Dude, I want your mods list!went for a top speed run and hit 50 mph on a relatively flat road. but i will have to confirm that. I have a mechanical speedo.
I lowered my handlebars a couple inches for better handling as well as for looks. I also fixed my chain tensioner, which is on my pedal side. I have trouble sometimes getting it to maintain the proper tension, because the bolt that's supposed to hold it in place is stripped or something and wont come loose. So what I did was, I took another nut and bolt and some washers, and stuck them underneath the idler wheel. I think one of the washers was a little small, and didnt grab right to keep the nut and bolt tight. So today I put a bigger washer on, and it seems fine now.
Bike was running like crap, so I had to replace the exhaust gasket, I also cleaned the head while I was at it.
I also figured out why these things have clutch covers, so you don't get the hem of your pants leg shredded.
Guess I need to get the cover back on.![]()
