DanielMaia
Thank you guys, apreciate the encouragement
All new gaskets:
All new gaskets:
very nice.
guessing that using sealed bearings like that will cut down on the need oil mix in the gas.
Ooooooo! Did you actually find the big end bearing made by SKF or is that for the small end?
This is the roller bearing that connets piston to the rod. This roller bearing is the big problem in these engines. If broke at high rpm's..you know what happens![]()
All new gaskets:
do any of you guys have any thoughts on the post i put up yesterday??
Ok yeh thanks gearnut, i appreciate you giving me the heads up, had no idea about hijacking, just thought you could add posts/comments at anytime. I thought i mustve been doing something wrong
