bairdco
a guy who makes cool bikes
when you get your frame stripped to bare metal, you can wipe it down with WD40 if you're not ready to prime it. if you coat it good enough, you could probably leave it in the backyard for a month with no probs.
i had an old stripped bike awhile back, and i'd rub a coat of WD in about every other month, and it'd sit outside all day at Newport Beach with no rust at all.
just make sure you clean it off with denatured alcohol or something before painting.
i dunno anything about the new sturmey hubs. had some of the old ones and they worked great. should be good, sturmey archer's been around forever...
i'm also thinking of going for a thin-walled, steel tank. i was all excited about using aluminum, since i got alumiweld soldering down pretty good, but trying to find something for a tank bung is almost impossible (my latest idea was the bottom end off a Mag-Light flashlight,) plus tapping holes in thin aluminum probably won't last.
i've been practising steel brazing with a bernzo map torch, and that's pretty easy, i can get sheet metal and threaded pipe anywhere, so i'm goin' for it.
