bajaracer1
just ordered everything i need. i decided to build my own jack shaft. i have a really good idea for it.
I'm gonna make a j shaft with a go cart front wheel hub, get them for $20 on eBay and lotsa colors to choose from. All it needs is to be bolted up to a plate. Gaaahhh, off with the covers! We wanna see your nude engine! Lol. I took the pull start off my 99, I will make a low-profile pulley to put on the flywheel so I can use a string to start it, even though I am making a manual clutch so I can bump start. You don't need the blower with a bike as long as you're moving. The pull starts make motor bikes look like goofy mini-bikes, not like a motorcycle. You can mod the engine while waiting for parts, start with a thin copper head gasket. Anneal the copper sheet first by bringing it up to red heat, it relieves stresses from rolling and makes for a better seal. That will bring up compression.
Where did you buy that from?i probably won't try it since i already bought the jack shaft setup.
dude, my idea uses a jack shaft. as long as you didn't already buy parts for a chain primary. a good clutch for this big of an engine will cost much more than $100 and it's fixed ratio.
