Micargi Puma with twin 97cc flat top lifan's
Seen in below matching red cloth wire. Both engines have had the excess mounting brackets shaved off. Makes for a nice shape.
Is that a real snake? Freaking me out Rat...as a kid I caught them in the oil fields but now keep me away.
Btw the motors and plug wires look good
Still to be trued but the spokes do fit! So anyone wishing to repeat this 234mm 12g spokes from http://holmeshobbies.com 90 cents each w nipples. Wheels look great! Lelu front and Motobcane rear.
The pix below show engine two (rear engine) adjustment slots. Pic one and two show the range of movement the third shows a back plate that will be attached to the engine mount. Holes in the plate will allow bolts to be inserted into the bottom of the engine block to pull engine two toward the plate and away from engine one. This adjustment should allow for tension on the #40 roller chain that keeping the engines timed.
The engines are now mounted solidly so the timing chain can be kept tight. Bolts are to long so I will replace them with what fits but all can see how this is going to work.
I'm like the lil kid at xmas who knows hes getting suntin cool every time I check in on this thread...hurry up already...lol...
Cutting it down now, lets see how this goes. That's Sledge on the cut off tool. Note in next entry the top is flipped over to allow for spacing.
Measuring where to make next cut. Wow those 22t timing sprockets look great in there with those twin engines!
You crack me up! Feel the same, now I got parts but its summer and all sorts of fun comes up that takes me away. Time to run the gold dredge, go camping and fishing....
Anyway it will be built!
Because I said so!
Goodness made major headway today between pulling crab pots! (Note it was opening day!) Working on the Puma Twin while the pots soak.
I'm a pirate! That I be!
I sail me ship upon the sea!
I stay up late - till half past three!
