msrfan,
So the thing I was pointing at in post 271 of page 28 (page before this one) that was the governor. Thought so. Can I just leave it alone or do I need to remove and plug it? With the different carb it can't be doing anything useful, right?
The point eliminator you refer to is also called an electronic ignition module, is that right? I think I'll follow your suggestion, but wait until after I have the engine running. I was the last one to run this a couple of years ago (on a snow blower) until it developed carburetor problems. If I wait to change the ignition until after and hook it up wrong then I'll know I screwed up there and that it isn't a fuel problem with the new carb.
And one other thing I wanted to ask you, since your Briggs engines have the same kind of engine tilt on your builds... should I have the same amount of oil in the crankcase? Does it need more? My initial plan is to switch the drain plug so that it is on the low side of the tilted engine. Then set it level and give it the correct amount of fresh oil according to the gauge on the filler plug, then set it in the frame tilted and check the gauge to see where the level is on it... mark that spot so that I'll have a reference point to judge whether or not I need oil and how much. Being an older engine it may well burn oil some, so I'll be checking regularly. Anyway, will it need the same amount of oil tilted as it would sitting level? And keeping in mind that it will no longer see winter use, but strictly warm weather, should the crankcase oil be a straight 30 weight? Any suggestions regarding what kind? Whew, that's a lot of questions...
Thanks!
SB
