Goat Herder
Gutter Rider
Suspense was just killing me and was a little board. My attack on my old ''dimpled'' Style clutch began to annoy me a little and all I could think of was the 3 fresh Grippa brand model clutch blocks I had just teasing me.
I took a Grippa clutch hub apart and saw the bolts shoulders that came with it were way longer. This was the hub that came out of the old full sus bike I built and had customized it to do a N.V. hub.. I looked at the shoulder bolts that came out of my stock air cooled BoXer and noted that they were like three whole flat spacer washers shorter. Huh?????
This would explain fairly easy why my old reported washer stacks on the first bike I built wound up different.
''Edit'' for later thought...... was up late last night thinking. Slept on it. Longer shoulder means different stack as the clutch blocks would be allowed to move upwards more by some 30 thousands of an inch. That is a big difference. This could very well lead to a whole different approach to clutch attack too!! Begins to match up with the Marten Slader KTM 50/65 sight??
Only wanting to obsess with what I was currently most familiar with opted to use the stock hub and the old shoulder bolts from the BoXer clutch. Then simply put the Grippa stones into the equation as the depth of the inside holes,washers, and bolts looked totally swappable across.
It was notable that the new stones were closer to the bell. Also I simply used my old stock bell as it did not look worn. Went and used old 30 grit sand paper diagonally from two directions to make a non directional cross hatch in the old bell as well. Slapped it all together on the old washer stack. Fired it up with no oil and briefly revved it the clutch seated in immediately . Or so I thought.
So pored in in the Lucas/Belray concoction and flat out shot out of the drive way. This is wicked!!! Half way around the block the clutch finish seating. Bike was a dog. This was predicted tho when I had observed the tightened clearances with the new pads compared to the old ones.
So quickly took the clutch back apart and added one flat washer to each stack.. bingo! Bad to the bone now!. It was time to give up on that old dimpled style stock clutch. It actually had parts of the stone surface that had chipped off disappeared and got digested. Never been truly nice to this motor. lol.The Grippa is now my favorite in this three shoe style model now.
Blue lock tight and always only about 8 foot pounds of torque on my old clutch bolts. Still cherry and don't have much shoulder wear at all from the stack washers. Just shiny spots. . The new washer stack will put washer wear in a different spot too as the bolts have been swapped around to new random locations as well..
Also after putting my stack at ( ) ( ) ( ) ( ) ( ) ( / / /. Two flat washers .254mm's and one .127mm. Can still grab hold of the stone blocks [clutch body in hand] and feel a tiny bit of play. So the cool thing is the washers are not preloaded. That's what was hoped for in this deal when I fretted over it. Reused my old bevel washers too. Will prolly change them later. Wanted to keep empirical testing specific.
Stock clutch was with 0ne .254mm and two .127mm's /// in the beginning ''stock'' and then switched to one .254mm and 0ne .127mm // in the end when I took it apart. I could have in now hindsight tuned it better.
New bevel washers would have left me wondering a bit about differences in what I was feeling perhaps? Dunno? Would have to put new ones in and report back. It is working perfectly at the moment so there is no hurry.
I did notice that the the Clutch hub bodies and the bells were a carbon copy dimensions wise from the stock clutch. [[[see post 72]]] The other shoulder bolts must be coincidental for a longer washer stack in a different model engine? As that was the only difference.. Bet that leads to some attack personality on the clutch I have yet to try! Could be very promising?!!
First time I used a Grippa stock like it was designed to be used. Note my other bike had a Jshafted N.V.... Machine runs like it did when it was 3 degree Fahrenheit last winter with no heat soak fade.. The dimpled clutch design never did impress me to be that intelligent as I begun to study this thing. I will not go that route again. Being fugal about it simply used it till it wore out. Still it worked good for awhile tho.
Road it for about 15 miles now need to fire it up again!
So a fellow can pick up 30 dollar grippa style clutches off ebay etc and swap the stones? Pretty sure at this point!!
. Simply Flawless...
