Tom from Rubicon
Night Rider, Go with what Dellorto recommends. PZ19 is a Mikuni clone.
They might weld it up for you, they're pretty good about requests. Maybe send a picture of how your engine is oriented now and they could get it close. I just tack welded my diy kit and then sealed with standard JB weld.Because of the angle of my engine, I have to use the diy kit. However, I don't have a welder, which is why I either need a carb that will bolt right on or a clamp on/spigot mount carb. I can use heater hose for the spigot mount carb, and if it's for a two stroke, then I'll just adjust the fuel settings until my engine runs well.
I have a 1/4" glass filter with a superfine plastic mesh. My gas tank attachment is a 1/4" elbow swivel barb, to clear my engine and ensure a clean line with no kinks. I have a petcock between the filter and the carb, where the line transitions from the 1/4" to the 3/16". No debris is causing a leak or a jam in that petcock. Yes, I used a clamp on the 1/4" line to secure it to the petcock. Before I did that, it leaked badly. I've not seen any sediment in that filter either. I expect to eventually cause of a dirty gascan or rusting tank.
However, I think that once I get the new wheels built, I'm going to start on my OCC stingray build, and put the 79cc on hold for a while. That bike will have a Harley street glide fairing on it, complete with a low wattage bluetooth 2 channel stereo system, gps speedometer, and a tach. My 178cc is an electric start, so I can run these things no problem. I do need new wheels for it though, so if anyone can help me source a 150mm hub, that'd be incredibly helpful.
I don't use a fuel screen, that's what the filter's for. If your fuel screen is causing problems, just delete it. My fuel system has no problems now, other than proper AFR.First thing this mourning I went to Ace and bought a hi flow/ capacity gas filter. Back home, plumbed it in and opened the petcock. Fuel system did not fill rapidly.
More like a drool.
Which likely is the reason for all the lean carb conditions.
Drained the two gallon tank. A time consuming chore. Unscrewed the petcock, the fuel screen was surrounded by tap threading chips. Went to NAPA and bought a replacement petcock which had that same intake screen. Installed it, and am getting the same low flow?
Took Curt’s recommendation and ordered a B&S cock with sediment bowl. It will take a bit of work to fit it in.
https://www.amazon.com/Briggs-Stratton-690612-Sediment-Assembly/dp/B0038U3JD4
Should arrive Saturday.
