culvercityclassic
I have been entertaining the idea of an e-bike build for some time and really wanted to build a one off type of bike that was capable of some fast speeds and some good looks. The end result is 48 volt 1500 watt mid-drive 7 speed shifter setup, Lithium-ion Battery between 15-20ah custom built to fit in tight to the frame. Fat tire setup with Maxxis hookworms, front and rear disk setup, frame combination of mild steel and stainless to mix it up a bit. Rear triangle will be an adjustable bolt on type that can be raised or lowered depending on the forks I choose to run. This bike will be a nice change from the gas bikes that’s for sure…Pictures to follow….
