Yes, - you have to have good strong spokes tying the wheel together. I've never had any problems with my tricycles despite carrying heavy loads, but then on the other hand I'm not trying to corner fast either.
Yes I've been getting out and about a bit Mike and I'm feeling much better than I was. Thanks for askingYup.
Bikes lean, cars and trikes don't. Wheels have to be much stronger to take the side load. Or it's taco time. Which leads to hospital time. And that's really expensive.
You been ridin' Anne? Feeling better?
---------------------Yup.
Hello Zoran,
From what I understand needle bearings are used for up and down motion only such as in connecting rods in engines. They do not do well with side force being applied where ball bearings can handle force from both directions much more easily.
Does your catalog show the 6904zz bearing. I think these numbers are used world wide. If Honda wheels are hard to find in Belgrade are there wheels that are of equal quality that can be used?
Steve.
The design of a leaner is actually remarkably simple, regardless of the number of wheels - for example any parallel dual a-arm assembly (arms of equal length) has the potential for leaning without adversely effecting camber, the difference is little more then an added pivot point;---------------------
Mike,
Then, solution is to design and make tilting (leaning) 3-wheeler (complicated) or 4-wheeler (even more compolicated)? There are mayn of such solutions, but I should replace one problem with many more, even I like tilting vehicles, HPV or motorised.
Thank you for the links Zoran
There is another link for the centre pivot steer quad......
https://www.youtube.com/watch?v=-b5Ue0xAA_c&index=2&list=UUgcRVnKT9hzx-F0MoS88YvQ
Judging by the video it seems quite capable of handling rough going.
[FONT=Comic Sans MS, cursive]Hello BaW,The design of a leaner is actually remarkably simple, regardless of the number of wheels - for example any parallel dual a-arm assembly (arms of equal length) has the potential for leaning without adversely effecting camber, the difference is little more then an added pivot point;
My (non-leaning) T3 during during construction;
For many more examples here's a link list, there's more - these are just the two-in-front taddys;
http://tiltingvehicles.blogspot.com/search/label/Pedal Powered - 2 wheels front
Ludwig,
...& some, like the Steintrikes 'Wild Wave' pictured above, about to hit the market...
..and then silence: https://www.youtube.com/watch?v=PqUe3J1vJV4 (don't bother, the vids are now "private")...
