When I pull the clutch my motor dies. I know this is vague but what are any possibilities. I can get my bike running smooth but pulling the clutch makes it idle for several seconds than it starts to slowly die, it is in the break in still.
and don't forget to be turning the throttle a little lifting the slide valveTurn the idle screw in or clockwise to raise the idle, you may want to run the idle a little high for the first few miles till the engine starts loosening up a bit.
Air, or vacuum leaks typically cause the idle speed to increase, not the other way around.must be an air leak, how do I fix that
