GEN IV dax build and review
mapbike
5,502
109
Central Area of Texas
I have a new dax motor as well. I developed a sqeak after about 200 miles. I isolated it to the clutch to sprocket shaft assembly. I pulled the sprocket cover removed the small bar and yes, there is a ball bearing inside shaft. I greased it up good. I also removed the cluth cable perch on the motor casing and pushed some grease in there as well.
The squeak is gone, for me.
Here is Happy Time Harry.
Good luck finding yours.
I too am quite pleased with this motor. Mine is still bone stock, for now.
Nice looking bike apex..... I like the rear mounted tank also, trying to figure out for sure what it is, looks kinda like a coleman cook stove fuel tank but cant tell for sure, whatever it is it looks like its doing a great job.
Map
rogergendron1
882
2
woburn ma
I have three of the GenIV dax engines and all of them as well as ALL other china girl/ HT engines have an 8mm ball bearing under the clutch pintle shaft, sometimes they may be covered with grease and this may lead someone to think it ient there but it is and should be well greased with high quality tacky red or other high quality grease, 2 stroke oil or any other oil is definitely NOT what should be used to lube the ball bearing, premature wear and possible running dry will cause damage and could cause a squealing noise if its not lubed properly with good gr8 ase NOT oil.
Map
.wee.
the only reason i used 2 stroke oil is cause i am dead poor and could not get any grease at the time lol the 2 stroke oil did take the squeek away and made it easy to pull in and it did even seem to stop the whear, 2 stoke oil is made for metal on metal contact and that is why i used it cause i had nothing else. i am getting some grease today and puling the whole shaft out and greaseing it !hopefully the squeek goes awy
rogergendron1
882
2
woburn ma
i have pretty mutch the same style frame sept i dont have a shwin lol and i have been wanting to do an in frame aluminum tank for a wile now and get rid of that stupid penut !
rogergendron1
882
2
woburn ma
ahh stupid thing ! now that its all broke in i cant seem to reach top speed here i think its a fuel problem as the main jet amy be too small. i pulled the plug and its grey so i am running lean and i think i will pull the carb apart to check and see if the main jet is clogged cause she wants to four stroke a little up to about half throttle then past there i seems like she is not getting enough fuel
what do you think ?
its a lil fat on the low end and four strokes when there is no load from idle to a lil over 1/2 throttle but past 1/2 throttle it bogs and looses power and my plug is comming out greyish instead of coco brown .
i think i will swap the stock .70mm jet for a .72 and a .74 to richen up the top end some and see if that helps out, i hope when i pull it appart tomorow morning i find that its just clogged and i dont need a new jet lol that would be a nice suprize ! but with the porting i did the high comp head free flowing exhaust and the larger boar intake i am just assuming i need a larger main. idk mabey there some crap cault in the emulsifacation tube where the main jet seats and not allowing fuel to pass though quick enough at higher rpms, whetever i will figure it out
any input would be greatly apritiated though lol
edit... ohh snap i forgot the cns has an enrichment circut instead of a choke ! i can activate it at high rpms when it bogs to see if thet fixes it ! also going to check for air leaks but theres not mutch to that lol just check the gasket and the clamp mount
chris8686
85
Bellingham
Larger jet sounds like the right direction to go. You increased the air flow and increased exhaust flow, therefore you must increase fuel. What oil mix are you going to run?
mapbike
5,502
109
That plug color looks good to me, I run my plugs that color or lighter with 100:1 Opti2 mix, very little four stroking at any rpm and runs cool as a cucumber on long wot runs......
Superior lubrication that I get with Opti2 is my recipe....... to much oil in the mix lenss the fuel/air mixture so a well tuned carb and 100:1 with a superior lubricant like Opti2 is a great combe for performance and engine protection in my experience, people that aren't running it just dont know what they're missing out on for sure.
Map
.wee.
apex
62
indy
Map
That tank is a windshield washer fluid reservoir from a 1970 VW bus. They were a pressurized vessel so its quite stout. Gas doesn't react with whatever its made from either. My peanut tank didn't last one fill before leaking.
I'm thinking about trying my hand at fabricating a small copper tank. I have a slip-roller and a metal shear at work, I've brazed pipe before, for plumbing purposes, so I figured Iwould give it a go. I ddon't know how to tackle the filler neck/cap assembly, so I may just use an-fittings.
On another note, how do you like the upgraded carb you put on the dax? I'm considering it myself, not sure which jet range to go for.
rogergendron1
882
2
woburn ma
let me know how the take goes wanted to make one myself... a thread might be in hand here when you decide to build !
i am thinking of swapping to opti 2 right now running true fuel pre mix 40 to 1. its a lil grey but i am not over heating or anything just not used to the grey plug on a 2 stroke i guess, i do however think a single size larger main is at hand. i cleaned the carb thorowly and put the old wet filter back on lol 4 stroking got worse and she ripps at the top end. i think the carb was a lil clogged and the filter is too wet to keep up with air flow. now that the carb is clean it should cut down on the 4 stroking when i put the new filter on tomorrow.
rogergendron1
882
2
woburn ma
a 16mm seems just the right size but if i had a choise in the matter and the money at hand i would go with a 16.16 dellorto sha not the clone or a 16mm phbg or the vm 18mm mikuni. make shure you use a larger boar intake than what comes with the kit, the kit intake was only 13mm boar lol no good for a 16mm carb found that out first day, swapped to a 16mm boar intake that was a lil longer problem solved ! i even have to rejet now from the extra flow.
chris8686
85
Bellingham
I am currently running a #64 jet from sick bike parts using opti 2 mixed 100:1. Amazing results with it. Smokes only while it's cold. My plug chops are a gray and my ports/cylinder crown is spotless. Previously I posted saying to go up a jet size but that was before looking at your pictures. I suggest starting with a #68 jet and do several plug chops before jumping to another jet size. It takes several miles of riding to get accurate plug readings. I lost my entire summer of riding to carb tuning and playing with oil mixes ratios because of inaccurate plug readings. My best advice is to choose an oil mix and stick with it and tune your bike to run that mix. I have a long thread on here breaking down my experience tuning my bike to run several different mixes and settling on opti 2. Opti 2 is made locally where I am located and I've never heard a single complaint.
mapbike
5,502
109
I really enjoy the added low and midrange performance increase with the RT Dellorto clone carb, it's much more responsive than the NT carb on my engines, I'm using the shorty manic mechanic type intakes on my engines that are running the RT carbs.
Dax has a great deal on the carbs, cable and filter.
Just a note: the throttle cables that dax has cor the RT carbs needs a very minor mod before it will work, the small barrel shaped end that goes into the flat slide in the carb needs to be either filed or ground down so that it's about half the length it is when it comes from dax, simple mod but has to be done or the cable wont fit into the slot in the slide so that the slide will have full range of motion .
Map
.wee.
rogergendron1
882
2
woburn ma
Map
.wee.
that carb is nice but its only 15mm i like along the lines of 16mm pluss usualy between 16 - 19 mm
if i was going to keep my motor stock or near stock motor that rt carb would be a great option ! but i already have ported it for high flow and high rpms and run a free flowing custom exhaust and have a light piston and piston mods, and the motor needs a bit more fuel flow from a larger carb for it realt benifit, it would make no since to get sutch a small carb and only have to upgrade later.
i am actually in the market for a new USED miuni vm 18
mapbike
5,502
109
Well its a "to each their own" situation on what carb one wants or needs for that matter, my engine is heavily ported and im getting over 9000rpm and a top speed of 45.3mph with th RT carb and very good power in the upper low to mirange rpm range all the way to top cruise speed, unless everything is just right even a bigger carb wont get a person any better power or cruise speeds, as far as top speed, I've hit 45mph with the little NT carb it just doesnt perform nearly as well in the low to midrange as the RT does.
If a person isnt careful they can do what I used to see people do back in my hot rod days and end up with an 850cfm Double Pumper on a mild 283 smblk which will not perform as well as what a 600 or 650cfm rated carb would do on that platform, the larger carbs are fine for real high flow china girl builds and there is some extra speed to be gained if tuned correctly and the entire platform is built to handle the added fuel and air supply, but in my experience what most of us do to our engines ranging from mostly stock all the way up to good porting along with a few other mods, the RT Dellorto clone carb fits the bill in an excellent way for a very broad range of china girl builds, it just simply does a great job of added performance in the area of throttle response and noticable torque and midrange improvement even on a bone stock engine and still performs great in the rpm range of 9000+rpms which is highr than most people engines will ever see.
I plan to experiment more with some other size carbs in the future, but for 95%+ of most builds im gonna say the RT carb well tuned is still the best bang for the buck.
Map
.wee.
Jumpa
607
2
Cape Cod
ok i am painting up the case bolts so they POP out and painting the long intake and swaping over to it, i want the larger dia boar and believe it will offer better flow, also started with the first coat of paint on the fins, and cleaned up and rebuilt the carb.
I must say I'm quite impressed I liked the bare metal look on the fins better than the orange paint on them.
For some reason the orange paint on the fins makes it look like rust at first glance.please note I mean no disrespect to your awesome project sir!
powerbike
13
B.C. Canada
Good thread. Read it all. Learnt some things , and going to try some of them.
Especially that 100:1 oil . i found a dealer close to me. Going to try some, I will let you know what I think about it.
mapbike
5,502
109
Best wishes and enjoy the Opti2 100:1 mix, its all I run now and wont go back to anything else....
Map
.wee.
thatsdax
868
4
16
www.thatsdax.com
Gray or alloy color appears on the tip of your plug from excessive heat and some cook off of your alloy piston putting alloy or gray deposits on to the tip of your plug. A lean condition.. If you are a racer and rebuild after every race, this can be acceptable since lean and mean is the way to win just short of a piston melt down. For the every day rider looking for a long life engine needs to be looking for a toasty brown color on the plug chop.
mapbike
5,502
109
Right on.....!
.wee.
