DuctTapedGoat
Shredding spokes with a shift kit? I'd say you need a higher quality wheel.
			sooo... this thread is HUGE... and I can't read 11 pages between now and when I'm supposed to meet with the dean.... and I have only my motorbike as transportation.... how do we quit breaking spokes? I'm shredding them with a Honda GX50 and shift kit!
I have not used boat trailer grease. But I do use Mystik JT-G, they dont call it mystik for nothing. In fact I use so much I buy it by the bucket. I have had great luck with it.
Another tip. If your clutch cable snaps,disconnect your rear brake cable and use that. It will get you home on just the front brake.
Isn't there a fix a flat can for bicycle like they have for automobiles?
There is a fix a flat equivalent for bicycles. Though, it takes just under two cans to get to the PSI I like in my aired tires.
I use 1" wide under ground rubber electrical splicing tape for rim.Streching it while wrapping 3 times.It will conform to rim and virtually become a solid piece of rubber.
Where can I find those fix a flat for bicycles? The ones at Walmart "slime" are for before you ride to prevent from having a flat. I want one that can fix a flat when I'm 10 miles away from home. I have a fear of getting a flat tire out on the road more than having engine issues. I can at least pedal home if it's an engine problem. I'm stuck like chuck with a flat tire.
