So Cal Race on Oct. 22 at Grange
headtrama
886
2
16
california
See Ya in the pits...yes you will. I will have 4 bikes that will race. Two of them will be 2-strokes and two will be 4-strokes.
I am sure that one of the 2-strokes will cause controversy with the motor I have built. Let’s just say it’s made by a relative of Frankenstein....and his friend Puchy
I an running those same parts so let the competition be warned . xct2
headtrama
886
2
16
california
Jeff, Your Bike looks great, can’t wait to see it. what is the part # for that Puch head? I’ve been looking for one for my ride and don’t know which one to purchase.
And D*cDave, don’t talk too much sh*t on the stock head because I’m going to be running a stock head at the Grange and if you remember I was running an unaltered stock slant head at Willow aswell……
Actually, the cylinder, bearings, connecting rod, piston and rings, intake, and Carb are all stock manufacture.
The only thing that is not stock on my engine is a modified intake manifold from MMechanic, air filter and exhaust from SBP, Dellorto main jet, and Jaguar CDI, which these don’t really qualify because it’s not part of my engine, it’s ‘bolted or added on’ to the engine.
3 weeks till the big race, and I’m ready…………I hope(^)
The stock slat heads are prone to warp and blow head gaskets even more so if milled . Just not enough material there .
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
I had some question about race dates so here is the plan
so everyone has lots of notice.
SoCal Motor Bicycle Racing Schedule for 2012.
It mainly comes down to the weather, daylight hours and being able to
space out three races in a year with enough time in between them.
Also avoid holidays and other undesirable dates.
When you consider all the above there really isn't a lot of room to move
the 3 dates.
I announced the Oct 22nd race right after Willow Springs as Sept 24th but
after looking at the weather reports for the last 10 years moved it to Oct 22nd
because the average temp goes down 10 degrees from over 90' to about 80'
I am glad the date was moved because Sat Sept 24th was 88' at 11.35am
and still 90' at 3.55 pm. Too hot to be wearing safety gear and helmets.
If you look at the Grange Race Track calendar there are almost no races
in September and October is booked solid for every weekend except for the last one.
Why? because it's too hot in September!
On November 6th daylight savings kicks in and it gets dark at 5 pm which is
really miserable as the days are really short and winter weather is starting.
There are no permanent lights at the track.
Never going to do a Grange race in November or December for many reasons.
Never going to do a race in August or September as it's way too hot.
That leaves October as the only choice.
I am paying attention to the weather this month and the race may be moved
by a week or two in October 2012.
I can give you the same reasoning for a race date in late March or April but
am still not 100% decided on the exact date.
The 2nd race of 2012 will probably split the time between March/April? and Oct
and will deal with the heat by being a night race under lights.
Anyone have some feedback?
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
25
38
Ridin' inSane Diego, CA.
Feedback: Just a silly idea and prolly near impossible to do would be night racing in the dark. This would require the bikes to have their own lighting and a couple of generators for lighting for the score keepers, the pits and whatever else that needs minmal light....a full moon would also help.
dnut
the 3 dates.
ducedave
370
4
18
Mentone Ca.
Nothing like a tight squish band .laff
a rose by any name -I spell deuce duce so squonch band is just more of the same dyslexic fun. speaking of fun I got my "NEWSED" that's used but new to me- parts to replace the piston on my RAW motor it lost the pin that holds the rings in place scarring the cylinder and braking the small beveled gear.I had a time of it porting as the cylinder has different ports, higher and smaller with a 90* edged transfer port the fist cylinder had the angled port for better scavenging so I went with a bigger power port and piston port as I run a reed block should be fine.
I'll build it to day and I guess we'll see how it runs
P.S. squonch!
headtrama
886
2
16
california
P.S. squonch!
What did the piston and cylinder come from
ducedave
370
4
18
Mentone Ca.
Best guess a RAW??? as that all he sells and the small beveled gear fits -maybe an old modal but it was free and I've all ready cut the ports so I'll run it. I always have mechanical problems be for a race event but that's how it gos I guess.
I'll be wright on and ready for Grange. I'll see you in the pits
P.S. squonch!
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
I am getting emailed quite a few questions about the race
so i am going to answer them here.
Do I need a CA motorcycle license to enter? I don’t have one anymore.
You do not need any kind of drivers license.
The SoCal Motorized Bicycle Race is an exclusively booked event at
Grange Race Track.
If you are under 18 a parent or guardian must sign a waiver.
Everyone must sign a waiver, both spectators and those riding on
the track.
Does the bike have to be registered? Silly question but it’s not registered. Most of the bike is built from E-Bay parts.
Your bike does not have to be registered.
Will the timing tower be operational or just the radar guns? My speedo only goes to 50 and I still have a fist full off throttle so I don’t know how fast it really goes and I want to.
There is no timing tower at Grange that measures speed.
Would I need elbow pads if I wear a leather jacket?
If you wear a leather jacket you do not need to wear elbow pads.
Are there any special requirements for the elbow and knee pads?
There are no special requirements for pads.
I have a DOT helmet. It’s open faced. Will that be okay?
DOT helmet is good and required.
Open face is OK too.
It’s a 430 mile round trip from here. Do I need to join anything?
You do not need to join any organization to race or ride on the track.
There are no additional fees besides the entry fee.
There is free camping in the pits on Friday and Saturday night.
You can stay and watch a Supermoto race on Sunday for no extra charge.
Will there be trophies for the winners? Never got one of those.
138cc Whizzer up against 160cc bikes. I’m not sure I ever will.
There will probably be trophies and there are all kind of prizes from
the race sponsors.
Opti 2 oil.
AGK - Home Page - Affordable Go Karts
MANIC Mechanic Parts.htm Manic Mechanic
Sick Bike Parts LLC - Performance parts for your motorized bicycle
Do I need to buy insurance or sign waivers or what?
You must sign a waiver and get a colored wristband before you get on
the track.
You do not need to buy insurance.
The insurance is paid for by your track entry fee and
by the $10 paid by spectators.
There is a 5 million dollar liability policy covering the race and
an EMT present for any medical treatment needed.
Is there a registration deadline or can I register at the track
You can pay at the track on Friday 21st or on Saturday 22nd at the gate.
If you register at the track it will cost $5 extra for track riders.
There is a special prize drawing for everyone that pre-pays.
A Manic Mechanic custom sized hub adapter which includes a sprocket
with the tooth count of your choice.
details to be announced soon.
Do you know of any Whizzer clubs in Southern California?
Sorry. I don't know of any Whizzer clubs or Motorized Bicycle clubs.
ducedave
370
4
18
Mentone Ca.
My motors back together it was raining here yesterday so I test road it this morning needs to be tuned in a Little, jetting and timing are are adjustable on my set up so I'm all most ready for Grange got to put on the lower bares fix the kill switch paint # plates BLA BLA BLA BLAdance1dance1dance1 I'll see you in the pits
P.S. THAT REALLY HOW I DANCE
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
any used parts or venders allowed?
Of course that is fine if anyone wants to sell or trade parts.
Do you want to sell a few parts?
what did you have in mind?
However if you are a vendor with a website and lots of products
please email me if you want to sell at the race on Oct 22nd.
If you make bikes like Taylor Motorbikes or Helmutt Cycles you are
encouraged to bring and show off what you are building.
I have already talked to both of those builders and hope that they make it.
Dan Taylar is located in Victorville, CA really close to Grange and
some of his builds are being ridden at the race by his customers.
Dan Orabona: 661-341-0192
[email protected]
ducedave
370
4
18
Mentone Ca.
They're not used they're 'newsed' as in new to me, spare part trading kept more then one bike on the track last time at Willow Springs - nuts, bolts, pedals and tubes with 5 patches on them all good stuff when you need them
dmb
1,354
3
36
lakewood ca
i bought some part's on a whimm [like 2 sets of suzuki forks] and some other used and new stuff i need do a little clean up thats all thanks. dennis
