MEASURE TWICE
I cut the rear triangle to clear the sheave. I will finish welding it with my brothers gas mig welder, and blend in those joins a lot better.... as well as the engine mounts etc, when i know everything is where it should be....
The last picture from looking at the bike with the garage door in background shows how close the lineup is for the clutch pulley and the sheave with one belt, but not quite.
So yea, you will get a jack shaft to fix that.
That also enables you to do more gearing down with the extra pulleys. You could then when not racing, get deep knobby tires and go on trails with massive gear down.
Go flying off top angle of hills in the woods, because you have at least front suspension!!!
Measure Twice
