http://motoredbikes.com/attachment.php?attachmentid=30075&d=1294959863I mounted my GP460 engine upside-down on my Scooterguy frame-mount adaptor. That left a LOT of room topside, so I installed a Happy Time expansion chamber system and ran the pipes between engine and the bike's top tube. Everything fit right in there, so I had room to install a 4-liter Happy Time fuel tank.
BTW, the exhaust bolted onto the 460 engine and fit snugly onto the bike frame. Performance-wise, it REALLY awakened this high-rpm engine.
And now it's quieter than a stock muffler.
Here's my bike:
my first engine was from bike berry and it was the cheapest motor i could get befor the Raw motors came out.. it was good at first but when I went over 30mph the bike would shake so bad my hands would go numb after 30 seconds... plus it was freezing cold out so I could not feel the break. I thought there was nothing I could do so I just put up with it.. after a year my motor starting to slow down so I just went ahead and bought a grubee! some people said I would have to place rubber from an old intertube between the motor mounts and the bike frame but I didnt waste my time. Now with the grubee motor I can get up to 45 plus mph "when I adjust the choke right" without anly vibration
Don't try to use your clutch to take off.
If you have to use the choke to make it "run right" then it'd NOT running right.
The choke it there for starting and warm up. If you have to use it any other time, you're not getting the most performance from your engine. May be causing premature wear or damage with the mixture lean enough that you have to choke it to run better.[/QUOTE/].
im just going to adjust the carb so I dont have to use the choke for better acceleration and higher top speed. I hate trying to adjust the carb because I always have to have the motor running when i do it, and I end dameaging the screw
What type carb do you have? The only screw adjustment on the stock carbs I know, is for idle speed.
If you need the choke to run right, sounds like running lean.
Try moving the needle clip inside the throttle slide, down a couple notches, this raises the tapered needle, allowing more fuel to richen the mixture.
Another possible cause might be the float level set too low.
Sometimes the gas caps don't vent. If it starts out running OK and starts needing choke after a few munites, try loosening the gascap.
In tank filters sometimes clog early from junk in the new tank. try draining gas into a container to make sure of no restrictons there.
The stock fuel filters don't always filter well. I've had one that you could see the element ratteling around loosely inside when running. Bad filter or no filter could result in trash blocking the carb float needle. To check this, remove float bowl and momentarily turn on fuel petcock. Fuel should dribble freely from under the carb
And how much heavier does the bike become after you put lead into the handlebars? Really want to reduce vibration, but I struggle enough as it is to lift the bike... Which I have to do when I get home to put it onto the steps to make room...
how about getting a rim trued and then using jb weld around where all the spoke adjusters are so it can not move and become un trued?? if they cant move then would the wheel stay true? if a few did move then we could see the jb weld broken and know those are the ones that need to be adjusted.... just a thought and i am going to try it out soon or maybe some tape or gorillia glue .. what do you guys think?
