hey kim - i thought id leave you alone for a couple of days, so you can enjoy your new baby, but i couldnt wait anymore, so have you installed it yet?
Sure have buddy, finished the mounting today-->
Today i fabbed up some aluminum mounts to hold the 2 Speed BoX to the frame
i have used 10mm aluminum 5mm stainless steel bolts to hold the mount together and
10mm stainless steel bolts to bolt the mount to the frame. Unfortunately i didn't have any 5mm
counter sunk cap screws and have had to use button heads, i will rectify this Monday and
acquire the right bolts, the 2 speed will then fit flush on the mounts surface. Heres
a few pics of how i made the mount-->
TiP: For those that haven't worked with thick aluminum before, when cutting it
if you rub some bath soap on the sides of the cutting disk, it cuts a lot easier as the disks' sides
dont 'grab as much
OK...so once it was all cut out and the holes drilled, it was time to mount it to the seat tube of the frame
All lined up beautifully... happy with the mounting I broke it down again and gave it a quick polish...
Saved some higher rez pics if anyone wishes to take a real close up gander of the mount
I may still get this mount anodized blue or black, unsure yet, still IMO it looks pretty neat
and the ThudSTeR 2 Speed has found its home at last
...all up the mounts took most of my day up making, with a long lunch break
to watch MotOGP Qualifying, racing in OZ this weekend WOOOtZ
...shall be fitting the lower aluminum
panel tomorrow ...getting a lil excited i seez it coming to gether!
Back with more soon chaps...
KiM
