I highly doubt it. Most auto parts stores don't carry motorcycle parts and accessories.
If anything, they might carry some cheap off brand pre-mix. I recommend staying away from those. An independent motorcycle shop would be your best bet, although some dealerships will carry it.
Edit: you can get it online too.
Maxima Super M
24:1 for break in & 32:1 after that is good. (There should be a chart on the back of the oil bottle for the mixing ratios.)![]()
The search at the motorcycle shops was exhasting , I like the Lucas products,,, but should i be using 24:1 ratio for the break in period ? The mixing ratio shows only 1 more oz of oil to the gallon, but i'm using 4oz to a gallon which is 32:1,,,, will this mess up my engine? Should i add another oz to the existing fuel & finish the gallon with that? over & out,,, DirtyLucas is good, definitely better that outboard boat engine oil or department store weed whacker oil.
It's not "really good" oil, but wallyworld sells a brand with that exact same bottle - I reused it over & over (the bottle, not the oil lol) until I eventually gave it to a buddy who kept "guessing" his ratio
Got myself a MixMizer graduated oil syringe... while it works jus' fine I kinda liked the bottle better dangit, I shoulda given him the MixMizer![]()
