thatsdax
Hello everyone. I got an e-mail from a guy. He has brought up a very common question about replacing parts and such to make for a better install. I answered it and will copy paste it now in order to help those that also have the same questions about install of the Dax Kit. Thanks...
Here is the comment and question that was sent to me....................................
I have been around the forums for a year before going with a Chinese kit. I've been riding an e-bike. I knew when I did get a Chinese kit it would be a DAX not because you said so, but nearly everyone that's owned one.
The point, it has also been recommended to replace all the studs and hardware. Do you believe its necessary to do this with your kit? I do realize in doing so it will void the warranty, but if YOU feel that it will prolong the life on the engine I'll do it. I have to say the bolts for the rear sprocket started to round off pretty readily. I hope that's not indicator for the quality of the rest of the crucial hardware. But if it is I'll replace it. No problem.
Here is my response........................................................................................
Hi... I have installed over 300 of these kits into bicycles. I have logged in thousands of miles on several of them. I have Customers, some with 10,000 miles and more on their motors. I can tell you this. I have never had to replace any studs or nuts with different ones or better ones because of poor factory steel or parts. Those that do are not properly installing. Also.. I have never ever used loc tight. Never. Do not use it. Also.. I have never had a problem installing or using the bolts for the rear sprocket. I have overtightened some bolts and had to replace them because of that. But that was my fault. Also. I have broken some front studs initially because of my poor install. Once I figured out what I was doing wrong, it was fixed using standard factory studs and none were ever broken again. As a matter of fact, the first time I broke the front studs, I replaced them with Auto motive grade 8, and broke them as well. My point being.. A proper
install will not require any upgrades to any of the steel or parts. Thanks... Enjoy the ride..
