Tom TG
Rick the rocker arm needs about a 1/4 inch more clearance. Its that darned hi lift cam . I may be able to mod the rocker and get the clearance I need.
The 3D clutch is going to take some redesign to fit my 1 inch crankshaft very few original parts will be left of it .
I need it on the crankshaft because I am going to put a one way clutch on the peddle shaft and that leaves no room for the clutch.
I left room on the rear hub for a future brake.
I plan on putting a compression release on one cylinder.
Here is a picture of the engine in the frame you can see the valve problem the valve is down.
