Hi Mr. B its good to here from you. I just checked out your link thats a nice bike you built.
I have been researching the peddle assembly that I need to make and just discovered that the peddle assembly needs to be an acentric so that you have a way to adjust the primary chain. So what I think I am going to do is build the peddles in an acentric and put the primary hub on the peddle shaft with a one way clutch in it so that I can peddle start it . This is my first build with peddles does this sound right. I know that some of these bikes had the one way clutch in the rear hub and had two chains going to the rear tire. Tom
Steve some how I missed your post thanks.
I have the same thoughts as Rick on to the cetrif. clutch .
I checked out the 3D clutch and ordered one thanks for all the good info. It really helps a guy that does not know about the parts that are avalible.
I have been working on the peddle assembly and am wondering about peddle stroke length and hight off the ground. Any help would be appreciated.
Here is the pictures.
View attachment 97299 View attachment 97300
Rick thanks for the info. on the peddles. I think I have enough ground clearance for a 5 " stroke.
I have been welding on the frame and cleaning up the welds it's a time consuming job and I am not done yet . But I am going to move on and finish that later. The rear drop out was made over size for the rear stand I am not sure how I am going to mount it so I left some extra meat on it.
Here is a picture of the frame and one of the engine being test fitted in to the frame and that's a tight fit. I my have to notch the lower tube for some rocker arm clearance.
View attachment 97442 View attachment 97443
