Steve some how I missed your post thanks.
I have the same thoughts as Rick on to the cetrif. clutch .
I checked out the 3D clutch and ordered one thanks for all the good info. It really helps a guy that does not know about the parts that are avalible.
I have been working on the peddle assembly and am wondering about peddle stroke length and hight off the ground. Any help would be appreciated.
Here is the pictures.
Tom, this is one of the design conflicts we face when dramatically lowering frame height thus placing the bottom bracket closer to the ground, which means using anything close to a standard length pedal lever will be dragging the ground. At just over 6' in height my ideal pedal length is 165 mm (6.5") on a bicycle, on both my Harley & Simplex build I reduced that to 4 inches & on the Simplex raised the pedal bracket about 3" above that 4" clearance height. In addition I used a very small 2:1 pedal ratio sprocket. I believe that was 12 t on rear and 22 t sprocket front. If you reviewed either of these two builds you will have noted that saddle height is not much higher than top of the rear tire. These bikes can only be pedaled with difficulty due to being unable to reach full leg extension. The only solution is to stand up a bit and pump or raise saddle height to allow full leg extension on the down stroke...there is no room to safely extend pedal length.
Forgive me for some of this explanation is basic knowledge for those who've ridden bicycles a great deal, but many have not, though they may be very accomplished on motorcycles. A basic skill that is vital on low slung design moto cycles, which also feature pedals is to "carry" your pedals level at all times and bearing quite a bit of ones body weight on them at all times. Riding with one pedal up & one extended down is bad riding technique even when biking in a straight line, but cornering or riding on uneven terrain (speed bumps) with one pedal lever down is asking for a spill. Cornering left or right with that corresponding pedal lever down & extended is an almost certain to result in a pedal lever to terrain hangup & usually a hard fall. Pedals carried level at all times is a good habit to get into.
Tom I'd suggest giving overall ride height (at the saddle) some real thought to get enough leg extension on your pedal strokes for starting your bike. Leg extension is what delivers maximum power to each pedal stroke. Many bicyclists use a "seat popper" which is a gas powered spring, to lower the saddle for control or stopping, while seated & foot on the ground, which at the touch of a lever elevates the saddle to full height for power. These are inserted into the seat tube & work great. I have one in my mountain bike and another to mount in something as may be required. Lot of words, but if you look at some photos of really low builds, especially those with large motors & motorcycle weight you'll realize why some chose to not include the pedal chain drive.
Your bottom bracket is coming along nicely. Rick C.
