Tingly arms
Discussion in 'Motorized Bicycle General Discussion' started by Tom in Kingman, Oct 31, 2011.
  1. Tom in Kingman
    Aug 21, 2010
    35
    Today after several relatively short trips around the block and such I decided to go for a "bit" of distance. I live rural on a dirt road. I have some friends that live about 4+ miles from me. I rode out to their house on my 500HP MB (OK, maybe 2 HP) and learned something. The road has about a jillion "riffles" which some refer to "washboard". I fought to keep the bike in tire tracks that were left by cars and trucks but I was not successful most of the time. Reason is that cars and trucks are not so plentiful. You can see more snakes than cars on that road. As a matter of fact for the entire 9 or so mile round trip there was not ONE vehicle (and thankfully NO snakes). The guy I visited told me about some kind of sponge hand grips that will keep my arms from tingling due to the road conditions. Anybody have any info on them?
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
  3. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    I like bars that are perpendicular to the saddle for a really good stress free grip- I use an 8 inch rise alloy BMX bar on both bikes- more rise may take some weight off your hands and ease the tingling.
    A front shock fork is also a great addition, but hard to find a one inch steer that's got about 6 or seven inches of length to fit moist cruisers- a springer fork is easier to find.
    These bars have a detachable center bar I reinstalled and the black plastic assembly at the front is for the removable Bell basket. You can just see the top of the shock fork I got on ebay from "curbhopper"
    #3 Nashville Kat, Oct 31, 2011
  4. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    My first build did the same...right up till it cracked a tube. This forced me to use a different frame (all the same kit components)....just about all the vibration was gone. I still can't hold/in a rack a open Pepsi can, without getting splashed.
  5. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    My years of riding would lead me to go along with NKat.
    When you get closer to apes configuration, it leads you to sit in a more upright position, taking the constant pressure off your hands, and arms, and putting it on your seat.
    ...which is why a plush seat is more important on a mab than on a pedal bicycle.
    (a pedaling bicyclist frequently puts a large part of his weight on the pedals, we rarely do so)
    ...but there's not much you can do abt a corrugated roadway! front/rear suspension, large, fat tires...
    Personally I never cared for the foamy type grips other than the initial plush feel of them.
    A larger diameter grip that filled my handgrip just a bit better , as opposed to a thin skinny grip always seemed to be an improvement.
    Gloves are a good thing!
    Best
    rc
  6. inked1974
    inked1974 Member
    Apr 11, 2011
    278
    Not sure if its right or wrong but I always fill my bars with spray foam. I can tell a huge difference. Just not sure if it would attract moisture or not down the road???
  7. GearNut
    Aug 19, 2009
    5,105
    inked1974, the spray foam should seal the bars from moisture. Also it is an epoxy sort of material which does not readily absorb moisture.
    _________________________
    Another way to dampen handlebars is to weight the last inch or 2 of the bar ends with lead shot or sand. The trick is to figure out a way to keep it there.
    Another idea is to get yourself some mechanics gloves with the vibration absorbing palm padding/ gel. They are marketed for use with pneumatic tools to reduce the inherent vibration that die grinders, impact guns, and such transmit to your joints, tendons, ect.
  8. rustycase
    May 26, 2011
    2,746
    Wow!
    That's a good idea, i74 !
    and GN, too...
    never thought of those ideas.
    rc
  9. vincent713
    vincent713 New Member
    Jun 2, 2010
    287
    I read somewhere on this forum a guy stuff bunch of rags in the handlebar and said it reduce vibration significantly. This might be your cheapest and easiest route. Snakes on road? Talk about trying to enjoy my ride with my worst phobia, this would really take the fun out of the ride. You would see me riding with my legs on the handlebar on that road! Try to imagine that. :D
  10. nightcruiser
    nightcruiser New Member
    Mar 25, 2011
    1,180
    I got some foam grips from this company, they make grips for bikes, mini-bike, motor cycles, etc, so make sure you choose the right size for your bars/throttle....
    Grab On Grips | Foam Tubing, Motorcycle Grips & Bicycle Handlebar Grips
    I really like mine, cheap and effective. You can buy directly from them, or they are selling on Ebay, Amazon and the like....
  11. Mozenrath
    Mozenrath New Member
    Jan 13, 2011
    340
    I only get tingly arms after 1+ hours of riding. You get it after only 4 miles? Holy ****.
  12. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    Just gotta take the bull by the horns. laff
    [​IMG]
    Actually the link to the custom foam grips looked pretty good!
  13. rustycase
    May 26, 2011
    2,746
    lol
    THAT's gotta be a Texas bike.
  14. Wm Holden
    Wm Holden New Member
    Jun 1, 2011
    358
    I need to address this myself.....I've got bbs and fiberglass resin....might try that.
