bbassfisher
You got to know that I asked santa for one of those "V" twins and was pushed down the slide. He then threw a lollypop at my haid! OW!!!
So is no news good news?
I don't understand why you would want to fire both cylinders at the same time that means the the pistons are at the top at the same time.
One of the advantages of the twin is that you can put the cranks any position you want, thus find the spot that eliminates the vibration. The Yamaha twin puts one up and one down that way you get a fire every half rotation. If you put the cranks at 90 degree that would put it in the same balance as a Ducati. Just a thought.
You have to run two carbs on a two stroke, the pulses foil the intake if you try to run only one. Have fun, Dave
yep im getting there on the final desine. butt im allso tring to get some other cool parts done to.im trying
 Dammmmmm!!!! That Is Sick.. Just Let Me know when you/yall Finish and is on the market so i can get me one
the motorcycle engines your talking about ar single crank twins and i think a single carb with a reed set up would almost erase pulse timing like my banshee with single carb conversion just got me thinking about this a bit just some thaughts off the top of my head
i useto roadrace a yahama tz 250 and have had several r5s and rds i curently have a rd350 with all the road race goodies on it.
 Excelent work!
 Excelent work! Just found this thread and it is like a dream come true! You are doing two 49cc motors right? Why not two of the bigger motors?  I would probably have to license it anyway.  My Stilletto chopper NEEDS this motor!  Just when I think I have spent enough money on my bikes you have to come up with this!
