MotorBicycleRacing
All you guys out there that have never been to a race because you
are unsure of your bike or riding ability.
The new 66 cc 2 Stroke Amateur Class is for you with a ton of very
cool prizes that will go to more than the first 8 places.
Get your safety gear on and race your everyday rider in this new class.
You don't have to have a ton of money in your bike for this class.
Grange Motor Circuit has helmets you can use if you don't have a DOT
rated helmet.
rated helmet.
Rob of www.PistonBikes.com is sponsoring the 2 Stroke Amateur class with
one of the Grubee aluminum frames with the built in gas tank.
Your choice of getting the one that has a built in mount or not so you can build a 2 or a 4 stroke.
SkyHawk Aluminum Bike Frame GT2-A for 48cc / 66cc
Features:
Built-in 2.4L gas tank
Pedestal front mount allows fitting of all 2 cycle bike engines with either 40 or 50mm front mount stud spacing
26" frame made especially heavy duty for gas engine applications
Available with 135mm rear frame width for either single speed or multi-speed bikes
38mm diameter downtube 70 degrees angle V frame
Material: Aluminum - No gas tank rusting
No other bike frame in the world is especially made for motorization
Seat post angle allows for level carburetor
Big bottom hole for 1 piece pedal crank
Net weight 6.5 lbs; Gross weight 10.50 lbs; Dimension (box) 43.70 in x 6.50 in x 22.24 in
SkyHawk Aluminum Alloy Bike Frame GT2A-S for 48cc / 66cc 2 Cycle and 4 Cycle
No pedestal mount
Features:
Designed for the late style 2-cycle engines with 50mm wide front mount stud spacing, and also accepts 4-cyle engines
The GT2S-A frame is made for the new 203 brg engines with the 50mm wide front mount stud spacing for big downtubes. This frame is not to be used with older 2 cycle engines with 40mm wide stud spacing at front mount No other bike frame in the world is especially made for motorization
Straight rear drop outs for easy chain tightening.
Cable eyelets for securing all cables.
50mm OD x 43mm ID stem
