nightcruiser
I tried 2 CNS carbs on a 66cc with no luck. Got a speed carb today and the bike runs frickin' great.
Not going to give up on CNS tho. Once the engine is broken in properly I'll be drilling the jet out and strapping that picky ***** back on there. I honestly think it can be a better carb once it's tuned properly.
One question, what exactly is 4-stroking? And what does it sound/feel like? Cuz one the way up to top speed the sound of the engine changes (of course), just wondering if it's normal-ish.
Thanks for all your guy's help!! This forum saved my ass!....and countless hours.
Wish I had pics cuz my bike looks dope.
I had a hard time with my CNS carb at first, in the long run I got it tuned up to perform great, I think probably better than the NT or RT carb, though I don't have any of those to compare.
From my experience the float adjustment in the CNS is critical, if the float is going too high before it pinches off the needle valve (gas level in the bowl too high) you will get a lot of four stroking cause lots of gas will be flowing. I had gas coming out everywhere before I did the float adjustment, from the vent, from the muffler, too much in the motor as evidenced by four stroking... After properly adjusting the float all that went away.
Another thing to watch on the CNS carb is the idle or pilot jet. Unlike the NT or RT carb, the CNS has 3 jets. The main jet, the pilot jet and the enrichment jet (choke). The pilot jet is really small, easy to clog, if it is not clear your low end speed will be very rough, you will probably need to screw your idle screw in all the way to get idle (which isnt right). The main jet from my experience might not be sized correctly fromt he factory. Some say the factory size should the that of a #70 drill bit, mine would only fit a #72 bit through (which is smaller). I opened mine to #69 (drill bit) and the bike ran really well with that jet and the stock air filter. I recently bought a CNS rebuild kit, the main jet in this kit did indeed fit a #70 drill bit through it like others had reported. I have heard 48cc riders say the carbs are too rich for their motors, perhaps the jet I got with my kit was meant for a 48cc motor, I dont know....
