indian22
Lew I'm always glad to hear members buy into this as a passion and that the forum is proving helpful to them. Metro areas are a challenge to riders I rode in Houston for many years, though I picked my times to play in traffic there was no way to avoid it. I prefer the country pace, still have to keep the head on a swivel, but it's a lot safer ride all considered.
I made some serious progress yesterday, but still a lot to do before I start to clean up and finish. One thing I mentioned in passing was engine offset to the right and I'm playing with balance to get the right offset and still feel right. Also there's always the motor to rear sprocket chain line to allow for & having the jack shaft in case limits adjustment somewhat. Also I want to be able to easily re-locate the motor case assembly, when the need arises, to the frame. The motor can be taken out of the case without disturbing the housings position & with the motor out the jackshaft bearing blocks can be removed, but I still want it to be relatively painless to pull the complete housing should the need arise.
I've cut ports for access to grease the bearing assemblies externally. I've not yet committed to welding in the case frame mounting lugs I see the need for three on the crank case. I'll also have one at the top of each cylinder to stabilize with the lower frame straddle tube.
Glad I started this, but probably wouldn't have had I known for certain what it would entail lol!
Rick C.
Rick C.
