Made some more progress on The Maytag Flyer.
Installed a three piece bottom bracket conversion and a wide crank and pedal set. The pedals will now clear everything nicely.
One problem is the sprocket that comes with the wide conversion kit, it is too skinny and flimsy compared to the original Worksman sprocket]
It is also bigger than I want for this bike, so I decided to cut it off and swap in the Worksman unit, after I rework it to remove the extra material around the drive lug hole. I will also have to machine up a spacer to locate the sprocket for the correct chain alignment and then weld it all together.
It was time to take the frame to my work to fit the front section back on.
As I was going to my work to use some tools I took a pair of leaf springs scrounged from old snowmobile skis from the 1970's and sand blasted them so I could use the leaf springs in the fabrication of the front end. These leaf springs should be light enough for my requirements.
I then took one of the main leaves and rolled its end like used on some early bikes. Here is a comparison pic of the stock and the rolled leaves, I am not certain which one I will use just yet.
