where did you get your jack shaft kit? the only one i've found is $200!Im working on getting one on my bike as I speak. Its a fantastic quality kit for the money. I can't wait to ride mine.![]()
its great to see that jackshaft kit now available, im ordering one right away, anyone else planning on trying one out?dan
so i guest they mainly charge you $200 for a front freewheel and 2 small sprockets and the bracket.
also for $200 one could also buy a new bike and engine kit.
1 Crank L & R & Freewheel 1
2 Bottom Bracket Spindle 1
3 36t Sprocket 1
4 44t Chainring w/chain guard 1
5 5/8" x 5.25" Jackshaft 1
6 5/8" Bearings 2
7 5/8" Lock Collar 1
8 17t Jackshaft Sprocket 1
9 10t Jackshaft Pinion 1
10 5/8" Bearing Washer 1
11 Bearing Bracket L 1
12 Bearing Bracket R 1
13 6mm x 35mm Left Bracket Bolts 3
14 6mm x 30mm Right Bracket Bolts 3
15 6mm Lock Nuts 2
16 6mm Nut 6
17 6mm Washers 6
18 Bike Chain 1
19 Rear Motor Bracket 1
20 1 1/8" Muffler Clamp 3
21 Motor Bracket Spacer 1
22 6mm x 35mm Rear Bracket Bolts 2
23 6mm split lock washers 2
26 Clutch cover 1
27 Upper chain guard 1
28 6-32 T-nuts 3
29 6-32 x 1/4 screws 3
30 Jump Stop chain guard 1
31 5mm x 25mm sprocket bolts 5
32 5mm washer 5
33 5mm lock nut 5
34 6mm shim washers 3
35 3/16" x 3/16" sprocket key
after seeing the list of parts you get for $179 it does look better,but i still wouldnt pay that.
a transmission or performance muffler should not cost the same as a engine.
Well actually there are three brackets and you get those items, chainrings, cranks, spindle, jackshafts, chain, chain tensioner,....well here's the parts list:
And it's ready to bolt on for $179
