where did you get your jack shaft kit? the only one i've found is $200!Im working on getting one on my bike as I speak. Its a fantastic quality kit for the money. I can't wait to ride mine.
this seems like a good plan, but cost is a bit high dontcha think? also, how exactly does this work????its great to see that jackshaft kit now available, im ordering one right away, anyone else planning on trying one out?dan
Well actually there are three brackets and you get those items, chainrings, cranks, spindle, jackshafts, chain, chain tensioner,....well here's the parts list:so i guest they mainly charge you $200 for a front freewheel and 2 small sprockets and the bracket.
also for $200 one could also buy a new bike and engine kit.
And it's ready to bolt on for $1791 Crank L & R & Freewheel 1
2 Bottom Bracket Spindle 1
3 36t Sprocket 1
4 44t Chainring w/chain guard 1
5 5/8" x 5.25" Jackshaft 1
6 5/8" Bearings 2
7 5/8" Lock Collar 1
8 17t Jackshaft Sprocket 1
9 10t Jackshaft Pinion 1
10 5/8" Bearing Washer 1
11 Bearing Bracket L 1
12 Bearing Bracket R 1
13 6mm x 35mm Left Bracket Bolts 3
14 6mm x 30mm Right Bracket Bolts 3
15 6mm Lock Nuts 2
16 6mm Nut 6
17 6mm Washers 6
18 Bike Chain 1
19 Rear Motor Bracket 1
20 1 1/8" Muffler Clamp 3
21 Motor Bracket Spacer 1
22 6mm x 35mm Rear Bracket Bolts 2
23 6mm split lock washers 2
26 Clutch cover 1
27 Upper chain guard 1
28 6-32 T-nuts 3
29 6-32 x 1/4 screws 3
30 Jump Stop chain guard 1
31 5mm x 25mm sprocket bolts 5
32 5mm washer 5
33 5mm lock nut 5
34 6mm shim washers 3
35 3/16" x 3/16" sprocket key
I'm sorry but in this case you are totally wrong. Compare the parts on your lil Chinese motor to the parts in the SBP jackshift kit. You will then see why I say you are wrong in this case.after seeing the list of parts you get for $179 it does look better,but i still wouldnt pay that.
a transmission or performance muffler should not cost the same as a engine.
Not to mention that you include the chain tensioner assembly in that new lower price.Well actually there are three brackets and you get those items, chainrings, cranks, spindle, jackshafts, chain, chain tensioner,....well here's the parts list:
Ever had to pay for the brake antilock device on a car? Might be the most expensive piece of equipement under the hood of a car and it does not even make the car go faster.after seeing the list of parts you get for $179 it does look better,but i still wouldnt pay that.
