MEASURE TWICE
Will the Tadpole be up on a center stand to pedal to start? I was thinking it is maybe too big to be easy enough to lift and have a center stand and how would it be stable enough?
I am pretty sure I understand the clutch with hand lever action is the same as before, just that the engine when pedal started will make the pedal freewheel so the faster running engine does not spin the pedals. Hense the special bearings added to modify the clutch.
Bump starting by holding in the clutch and letting it out to start the engine when going at a slow pedal rate across the ground is the way it will be started?
