HF 212cc capable reverse gearbox?
McChicken Messiah
I'm mounting a HF 212cc Predator with the crank facing right, and I need to reverse the PTO.
The engine must be mounted this way, or I'll have to do some serious hackery to the frame, which I would really prefer not to do (I don't have the proper tools to fit the frame for left crank facing mounting, and I'd still need to setup a jack shaft for my purposes).
After some digging, I haven't found a reverse gearbox that I'd feel safe using.
A sturdy reverse gearbox or some other suggestion as to reversing the PTO without fab would be extremely helpful.
Keep in mind, I'm not going to purchase a new frame.
This is what I'm working with, space wise I won't be able to mount it "the right way" without chopping the frame and bracing the engine from the gas tank mount.
Thanks for the welcome SB.
Ahh, guess I missed this post on my first searches here. Though, this is similar to what I was originally thinking.
Hmmm, any suggestions out there on a gear train parts supplier?
If you can find someone to make an inverted cam in theory you get the motor to run and reverse
you would also have to make a different pull start
