Anyway, even with a spring loaded tensioner, I've still had to reposition it a few times as the chain wore in.
That's true IF you have horizontal drop outs or the frame design allows it. Some frames, like the one I pictured above with the severe taper of the chain stay from front to rear, do not lend themselves to running without a tensioner or some type of guide to keep the chain away from the frame.
I run no tensioner whenever I can but it's not always possible with every frame design.
The bracket doesn't need to move. If you allow enough adjustment by making the slot long enough the welded bracket will work perfectly.
I did this one on a 24" bike I built a couple of years ago. After two owners It's still on the bike and still working.
Good Job, Maniac. But my paint matched better than yours
